Terrain for Knight Spearhead
AdeptiCon 2016 will be held March 31st - April 3rd, 2016 at the Renaissance Schaumburg Convention enter. Visit the AdeptiCon website (http://www.adepticon.org) and start planning today!
Postby BigKahuna » Mon Apr 11, 2016 7:34 pm
Can someone please let me know how they made the rocky formations that were used as terrain at the Knight Spearhead event?
BK
BigKahuna
Re: Terrain for Knight Spearhead
Postby muwhe » Tue Apr 12, 2016 9:03 pm
From Ty,
Hello,
Basically it was built using sheets of this stuff:
http://www.corkstore.com/Products/Cork- ... ts-2x12x36
It's a large initial investment, but if you split it amongst a group it works out ok. The benefit is that you will end up with more craggy rock terrain than you know what to do with. Several 6x4 tables worth easily.
It may also be possible to get individual sheets at a Grainger, other specialist outlets, or if you are friendly with a contractor - you'd have to do some legwork to find out.
Anyways, we used 2" and 3" sheets. 2" being quite flexible as you can use it as is, or glue 2 pieces together for a 4" chunk and go from there. 3" is a nice midpoint as well.
First you cut out rectangles of cork to the approximate size/height you want the rocks to be.
Then you just attack it with a screwdriver or knife and whittle away the shape, careful not to make any areas too thin. it is cork and it is fragile.
when the shape is to your liking, mix up a vat of 60/40 wood glue/water and brush it liberally over the rocks - get it everywhere. Let it dry. This helps reinforce the semi-crumbly structures a good deal. You can then glue some sand in place for more texture.
Lastly, add a base of some sort. Then you simply spray layers of color as you see fit form the top down, you really don't even need to pick up a brush.
When you are all done, you will have lots and lots of unused smaller cork pieces laying around. These can be made into smaller rock outcroppings by hot gluing them to a base and treating them as above. Let nothing go to waste.
Hope this helps.
-Ty
Postby BigKahuna » Wed Apr 13, 2016 5:41 am
Awesome! Thanks.
BK
BigKahuna
Postby cjputrich » Thu Apr 14, 2016 9:34 pm
Can anyone post a pic of this terrain? I must have missed it but am now quite curious.
40k Armies
Chaos Space Marines
Dark Angels
Other Games
Fantasy - Skaven
Warmachine - Khador
X-Wing
Infinity - Ariadna
cjputrich
Postby BigKahuna » Thu Apr 14, 2016 10:05 pm
Here is a pic of the table. You can see the rock formation that they created using the cork insulation.
BK
BigKahuna
Return to AdeptiCon 2016
Users browsing this forum: Baidu [Spider] and 4 guests
