lucius pattern drop pod
Postby beeny13 » Thu Nov 12, 2009 8:01 am
does the lucius pattern drop pod need to be the size of the forgeworld model or can I just use a regular plastic drop pod?
beeny13
Postby Smoke_Bomb_Ninja » Thu Nov 12, 2009 8:31 am
According to the Adepticon model policy you have to use the actual FW model so a regular drop pod or conversion of it would not work.
http://www.adepticon.org/09rules/modelpolicy.html
"Because of the uniqueness of Forge World models and rules, Forge World
units (i.e. units found ONLY in Forge World rules supplements) must be
represented by the appropriate Forge World model."
Smoke_Bomb_Ninja
Postby Matthias » Thu Nov 12, 2009 2:08 pm
That is the 2009 Model Policy. It has been updated for 2010.
http://www.adepticon.org/10rules/2010modelpolicy.pdf
The most important part relating to this question:
The size and shape of all model bases MUST be appropriate for the given game system. Models, such as vehicles, that do not require bases MUST maintain the intended size, shape and height of the model represented.
This means that you are free to scratch-build or convert a Lucius Pattern Dreadnought Drop Pod, but it the model must maintain the size, shape and height of a standard Forge World Dreadnought Drop Pod, as pictured here:
http://www.forgeworld.co.uk/dreaddrop.htm
Postby beeny13 » Thu Nov 12, 2009 4:07 pm
thanks
beeny13
Postby Arander » Fri Nov 13, 2009 12:16 am
I emailed Chris M about this and he told me that the FW Dreadnought drop pod would be required to run this unit. Has that stance changed then?
Arander
Postby muwhe » Fri Nov 13, 2009 9:53 am
The AdeptiCon model policy has been updated and is more flexible. Let me stress however. They better look the part and pass the smell test. In otherwords.. if your going to scratch build something, it better be at least as good or better than the available model. When in doubt I'd be sending photographs.
Postby drgabe » Sun Dec 27, 2009 10:19 pm
So quick question here.... can I use the plastic drop pod and 'mod' it to fit a dreadnought? It is a bit smaller in all dimensions than the FW Dreadnought DP, and about $70 cheaper.
Thanks
-DrGabe
drgabe
Postby Matthias » Sun Dec 27, 2009 10:35 pm
The Lucius Pattern Drop Pod offers a significant advantage and MUST be modeled accordingly.
If you can modify a plastic drop and in the end have is match the size/height of the FW model - then yes, but you cannot field the normal drop pod as a Lucius Pattern Drop Pod.
This is the official ruling on this question:
Postby Rhysk » Sun Jan 03, 2010 1:47 pm
Arander wrote:I emailed Chris M about this and he told me that the FW Dreadnought drop pod would be required to run this unit. Has that stance changed then?
The answer I provided was based on the 2009 policy. Since then the policy has been updated. Please refer to the 2010 model policy.
Regards,
Chris
Rhysk
Postby lordnurgle » Sun Feb 07, 2010 12:23 pm
I posted a question about lucius drop pods on the rules forum. I was wondering how the drop pod assault works with space marine armies that do not have drop pod assault. probably should have posted here, but I did not want to double post.
it is posted here
http://adeptuswindycity.com/forums/view ... 9843#39843
lordnurgle
