Warmachine slotted bases
Postby cjputrich » Wed May 14, 2014 9:53 pm
I recently started playing Wwarmahcine and I'm not sure the best way to deal with the slotted bases.
On larger models it doesn't matter because I use cork and such to make hills/rocks, but for the smaller infantry there are gaps. Is this something you guys generally just fill in with glue or is there a better approach?
40k Armies
Chaos Space Marines
Dark Angels
Other Games
Fantasy - Skaven
Warmachine - Khador
X-Wing
Infinity - Ariadna
cjputrich
Re: Warmachine slotted bases
Postby tulkasulmar » Wed May 14, 2014 10:03 pm
I use green stuff to fill in the gaps. You can also use tape to tape over the gap. And just cover it up with flock.
(2014)
Painted:
255 bases/trays
10 Demons
74 Astra Militarum/Militarum Tempestus
68 Grey Knights/Inquisition
15 Adepta Sororitas
1 Fortifications
192 Commission
tulkasulmar
Postby cjputrich » Wed May 14, 2014 11:44 pm
Thanks Jeff! I hadn't thought about green stuff, I'll have to give that a whirl - probably holds up better than tape.
40k Armies
Chaos Space Marines
Dark Angels
Other Games
Fantasy - Skaven
Warmachine - Khador
X-Wing
Infinity - Ariadna
cjputrich
Postby eltrain728 » Thu May 15, 2014 7:27 am
Idk much about WMH bases, but for GW slotted bases I used to trim bits of sprue and glue them into the slots (or gaps in the slots) then use green stuff (or liquid green stuff) to fill in the voids.
GL
eltrain728
Postby Redbeard » Thu May 15, 2014 8:46 am
I've had success just making sure there was PVA glue in the slot and letting the sand or other basing material fill in the gap.
