foam paint sealers
foam paint sealers
Postby BostonNazgul » Fri Jul 01, 2011 11:15 am
I am working on a large terrain project consisting of 90% core foam material. It will involve a lot of smaller, pointy detail work to be added on.
usually I just use foam for board or terrain bases and cover with sand/gravel and then seal the entire thing with a layer of mixed wood glue, textured paint, and water. so that a base spray paint coat wont melt the foam.
for this project I want to try to avoid brushing on a sealing layer.
does anyone know of spray products that can safely be used on foam to give me that sealing layer from spray paint?
-Jeremy
Postby Elthniar » Fri Jul 01, 2011 11:47 am
You can by water-based black primer at Menards. I think Rust-Oleum is the brand, and it is called Aqua or something like that. It will not melt foam and once you have a layer down you can spray anything on top of it.
Elthniar
Postby BrentS » Fri Jul 01, 2011 11:49 am
Airbrusing acrlic paints should work? Not sure if that is an option.
There are some cool products at Hot Foam Factory:
http://hotwirefoamfactory.com/FoamCoat-glue-foam/
They even have a non-dissolving spray on glue.
Postby CmdrVimes » Sat Jul 02, 2011 10:39 am
I've had good luck airbrushing foam. It looks good and goes on thinner than any spray paint. It also lets you layer and shade while you spray.
CmdrVimes
