Need a good sealer for display board
Postby GregSwanson » Thu Mar 10, 2011 2:32 pm
Just wondering does anyone have a good sealer that works to keep your display board intact? Would be even more beneficial if it was spray on.
Thanks
Greg
That crazy fireman!
I am not smart but I can lift heavy things!
In the grim darkness of the future, there is only war. There are not massive army costume parties and campy parade floats. - xNickBaranx
GregSwanson
Postby Redbeard » Thu Mar 10, 2011 2:39 pm
What is the display board made of? Are you sealing paint, or flock?
I used a wood stain and then a polyurethain spray on my display box, for the wooden panels, and that has held up well.
For flocked parts though - I don't know. Maybe something like a krylon matte sealer spray?
Postby BostonNazgul » Thu Mar 10, 2011 3:09 pm
for flock sealing i simply use matte finish that i use for my models. works pretty well
Postby muwhe » Thu Mar 10, 2011 6:03 pm
If it is foam ..
Check out Hot Wire Foam Coat products.
Postby EldarCorsair » Fri Mar 11, 2011 1:43 pm
I seal mine with Createx Matte Varnish. Goes through my airbrush at ~40psi, mixed with a little Illustration Base.
The nice part is you can spray indoors (so long as you wear protection) in the cold/rainy weather. Dries in ~30mins-2hrs. It also won't melt foam like spray can sealant will.
EldarCorsair
