Offical BBB FAQ
All the latest and greatest info concerning the constant struggle and strife across Middle-earth!
Offical BBB FAQ
Postby BrentS » Sat Oct 06, 2012 11:07 am
We have put together the offical FAQ document for BBB. You can find the pdf following this link:
Edit: Updated version http://bilbosbirthdaybash.files.wordpre ... ct2012.pdf
Re: Offical BBB FAQ
Postby BostonNazgul » Sat Oct 06, 2012 11:44 am
The Fallen Realms
Q: For Thrydan Wolfsbane’s Mighty Blow special rule, are both wounds prevented by
one successful fate roll? (pg. 18)
A: No. Mighty Blow causes Thrydan Wolfsbane to cause 2 wounds for each successful to
wound roll before fate rolls are made. Note: Mighty Blow differs from The Knight of the
White Tower’s the White Sword of Gondor special rule. Mighty Blow causes 2 wounds
for each successful to wound roll before Fate rolls.
I am confused as to your ruling. To me you use the word "before" in both statements thus showing both the knight and wolfsbane are the same, not different.
Re: Offical BBB FAQ
Postby BrentS » Sat Oct 06, 2012 5:37 pm
I'm confused by your confusion. In the answer, its states that Mighty Blow rule takes precedent before fate rolls are made, which is different that the KoWT's Sword of Gondor special rule. There are two uses of "before" but they both refer to the same special rule (Mighty Blow). Perhaps we should just remove the last sentence since it is just repeating the second sentence.
Re: Offical BBB FAQ
Postby BostonNazgul » Sun Oct 07, 2012 12:41 am
yeah it is just the last sentence. it makes it seem like you are stating the white knight's rule when in fact you are just reiterating the rule from above.
Re: Offical BBB FAQ
Postby BrentS » Mon Oct 22, 2012 8:27 pm
We updated the FAQ for BBB based on the most recent GW FAQs.
You can find it here:
Return to Lord of the Rings News
