Fall of Orpheus IA 12
The place to discuss relevant News and Rumors!
Postby seahawk » Mon Apr 08, 2013 11:58 am
Copied from elsewhere from people who went to FW Open.
Necrons
Necrons have received a full new army list named Dark Harvest Legions of the Maynarkh
New warlords trait table for Necrons:
1 = +1 or -1 to reserves
2 = Warlord survives game +1vp
3 = Must issue and accept challenges +1vp for every enemy character killed in a challenge
4 = Whilst within 3" of objective warlord and unit get to re roll re animation rolls
5 = Can give a single ranged weapon +1 strength each turn
6 = Warlord gains the crusader USR
Warlord table for Death Korps
1 = The warlord and all DK's units within 12" add +1" to their charge roll
2 = Whilst warlord is alive select a single unit within 6" of them in the shooting phase that has the ordnance special rule the weapon counts as twin linked this turn
3 = Warlord and unit within 3" of Obj gain Fearless and FNP 6+
4 = Can auto put night fighting on in first turn
5 = Warlord and any DK's unit within 6" gain prefered enemy infantry when in the enenmy deployment zone
6 = Nominate a single piece of terrain in enemy deployment zone the cover save is lowered by 1
2 new named chracters
New versions of existing units IE Royal court of maynarkh
Yes flayed ones are troops and can have flensing scarabs which gives them shred
Tesseract Ark
250pts
12 armour all round
4HP's
Heavy Support choice
3 fire options
Solar Fire Rg 48" Str 7 Ap 2 Heavy 3 Blast
Particle Hurricane Template St 3 Ap 3 Fleshbane
Seismic Lash Rg 24" Str 5 Ap 4, Heavy 1 Quake, Armourbane, Ground Lash (hits in a thin line like the death ray)
When weapon destroyed occurs on a 4+ the ark is destroyed and all models within 6" suffer strength 6 ap - hits. Also str 6 from an exploded result.
Acanthrites,
150 pts for 3 jump infantry
armed void blade and cutting beam rg 12" Str 6 Ap 2 Assault 1 Melta
Can be a fast attack choice in necron list
Toughness 5 Wounds 3
Also fearless and stealth
Tomb Stalkers are elite now as the new Tomb Sentinel is in the fast attack slot.
its 195pts
T7 beastie with 4 wounds
MC
Fearless, Rampage, War Construct and Phase Tunneling
Armed with and Exile Cannon
Rg 12" Str X AP - Heavy 1 Blast
The number of models hit under the template have to take a strength test or be removed no saves allowed. It is random which models are hit.
Phase tunnelling gives Fleet, Deep Strike, Outflank and Hit & Run (interestingly its I 4 no doubt so it can use this ability as most cron stuff is I 2)
War Construct makes them immune to Fleshbane and Poisoned rules.
Optional upgrade Sepulchral Scarabs means it gains it will not die!
Charnal Lychguard
225 pts for 5
Warscythe armed
Have Rage and Fear
Soldiers of the bloody court: Only 1 unit per Overlord in the Army
Can add flensing scarabs giving them shred
Can exchange warscythe for shield and sword like normal lychguard
The Gauss Pylon (Apoc) is mostly the same.
One change:
Flux Arc used to be heavy D6 to all enemy units in range.
Now it seems to be 2D6 to one unit only!
And for the big finale, what you've been all waiting for:
Necron Tomb Citadel
300 pnt fortification for 40K!!!
The two big buildings are both AV14 and each penetrate results into a D6 (5+ destroys it)
Ziggurat:
has both Eternity Gate and Scarab Hive (check Codex! Scarab Hive is broken when you roll a 1)
docked Monolith or Sentry Pylon fire with STR+1
If destroyed, the docked machine takes STR10AP2.
Power Crucible:
Units, Crucible and Ziggurat on the Citadel have 3++
All RP-rolls of 1 can be rerolled on the Citadel.
Optional:
Comms Relay for 20
Up to two Tesla Destructors or Gauss Exterminators with Skyfire/Interceptor for 65 or 100 each.
Minotaurs get a new vet Seargeant Hamath Kraatos 60pts
Replaces a devastator seargeant
Armed with a heavy bolter which can be fired normally or with the following profile:
Rg 48" Str 6 Ap 3 Heavy 1, Sniper
Signum: one model in the unit can count as having BS 5.
He also has prefered enemy
Rules for Necron Realm of Battle Board (Fortification)
https://picasaweb.google.com/1131330762 ... 0370152418
Bomber 225pts
12 armour all round + quantum shielding like the teseract armour 14 Awesome!
4 HP (yikes Av 14 fliers...)
Five death sphere bombs Large blast Str 10 Ap 1, Blind and Pinning
New Necron Lord Kutlakh The World Killer 220pts
Kutlakh Stats
5,4,5,5,3,2,4,10 2+
He has a Staff of Light and The Obsidax
The obsidax is a close combat weapon with the following profile:
Str as User (5) Ap 2, Instant Death, Specialist Weapon.
He also has the splinter of madness...
He must declare a challenge...
Before the challenge takes place both combatants roll a d6 and add their leadership If Kutlakh's total score is greater than that of his opponents, his opponent suffers a reduction to their weapon skill for this assault phase equal to the difference. Opponents reduced to 0 cannot fight this phase.
New Necron Units from Forgeworld:
For Necrons we have:
Kutlakh the World Killer
Toholk the Blinded
Canoptek Tomb Sentinel
Tesseract Ark
Sentry Pylon
Nightshroud Bomber
Necron Tomb Citadel
Minotaurs
Damocles 75 pts
Can be used with as an HQ choice Space Marines, DA, BA, SW and BT
Can bring in orbital bombardment once per game Str 10 AP 1 Large Blast, Barrage.
Teleport Beacon units arriving from deep strike within 12" do not scatter
Command Vox Relay
Allows player to add or subtract 1 from all reserve rolls
Dread is called Hecaton Aiakos
225 pts
Can be added previous minotaurs list or used in codex space marines as an elite choice.
FA 13 S 12 I5 rest as normal
HP 3
Plasma cannon
Special Rules
Augmented Atomantic Shielding
4+ invulnerable vs shooting attacks, 5+ inv in close combat in addtion add +2" to the radious of explosion results
He is venerable
Groundstrike:
Instead of making normal cc attacks he can chose to make a groundstrike attack at I1. It automatically inflicts 1 hit against each enemy unit engaged with Aiakos for each model in that unit in base contact with Aiakos model. So for example, if Aiakos is in base contact with three models from an enemy unit, the unit suffers 3 hits and so on.
Str 6 Ap4 Melee, Strikedown.
Re: Fall of Orpheus IA 12
Postby muwhe » Thu Apr 11, 2013 3:09 pm
So looking forward to this book!
Postby Lord Krungharr » Fri Apr 12, 2013 10:38 am
That bomber sounds horribly potent. Not sure about anything that could take that one down, even a flying Daemon with the S8 Lance shot would be slim odds. Good thing it wasn't released in time for the Gladiator !
Return to News & Rumors
