New Site, Styles and The Future...
The place to discuss relevant News and Rumors!
Postby Matthias » Mon Feb 06, 2012 6:02 pm
OK - everything should be good to go at this point.
All old topics, permissions and links and been moved.
There are currently to simple styles/skins you can apply to the forum. The default one is titled Bl@ck and is most likely what you are seeing now. You can switch the style to proBlack in your User Control Panel under Board Preferences --> Edit Global Settings --> My Board Style. This will make the site look somewhat similar to the old forums.
The current styles/skins are just temporary. I will work out something better down the road (and hopefully offer 3-4 different styles to choose from). I will also look into integrating some MODs (PM text in email notification) possibly integrate the Gallery. If you have any feature requests, let me know and I will see what I can do.
3.0.X also also you to easily add custom profile fields. Any suggestions for useful fields to make the profiles more useful?
Re: New Site, Styles and The Future...
Postby RAMSEY » Tue Feb 07, 2012 3:16 pm
Great job on the revamp of the site. Looks awesome.
"YOUR SUFFERING WILL BE LEGENDARY, EVEN IN HELL"
No wait! That doesn't sound right.
RUMRUNNERS Gaming Group
Nephilim Jet Fighter…….. What’s it fighting?.... BALLOONS!
RAMSEY
Postby Thogrid » Fri Feb 17, 2012 11:15 am
I must agree...this is spectacular! Nicely Done!!
Merle
KC Area
"A wise man learns form his own mistakes, but a genius learns from others!"
Thogrid
Postby Redbeard » Thu Mar 15, 2012 9:35 am
I noticed an inconsistency while posting earlier.
The buttons that apply certain tags typically create both an open and a close tag. For example, if I click the B button, I get both a [ b] and a [ /b]. If I select text and click the button, it's smart enough to put the [ b] at the front of the selection and the [ /b] at the end of the selection.
This appears to be true for all the buttons except the [ *] button, which only creates the open tag.
Return to News & Rumors
