Card Buildings
Discussion concerning the latest version of the Epic 40K game system.
Card Buildings
Postby Spectrar Ghost » Sun Jan 10, 2010 4:22 pm
Good News! I've scanned all the card buildings!
Now we can just print, paste, and cut more.
http://s977.photobucket.com/albums/ae26 ... Buildings/
If anyone would like me to email these files to them, PM me.
I'm in the process of measuring the roofs to make more from plasticard. I will add the dimensions when I finish.
Nat
Last edited by Spectrar Ghost on Sun Jan 10, 2010 5:01 pm, edited 1 time in total.
Spectrar Ghost
Postby Spectrar Ghost » Sun Jan 10, 2010 4:59 pm
Each of these will have the starting dimensions (rectangle) and dimensions of cut-outs from the corners going clockwise from the top right.
Original
Tall (Off center cross)
108x108
26x26
58x26
58x58
26x58
Tall (Swiss Cross)
88x88
32x32
32x32
32x32
32x32
Short (T)
69x51
16x30
32x30
Short (Cross)
69x81
31x12
31x12
31x36
31x36
Scans
103x103
25x25
55x25
55x55
25x55
Tall (Swiss Cross)
85x85
31x31
31x31
31x31
31x31
Short (T)
77x56
34x33
20x33
Short (Cross)
89x76
33x12
33x12
33x41
33x41
Last edited by Spectrar Ghost on Mon Jan 11, 2010 9:42 am, edited 1 time in total.
Spectrar Ghost
Postby Spectrar Ghost » Sun Jan 10, 2010 10:53 pm
So, after investigating the scaling problems scanning created, I've discovered that my scanner scaled the taller buildings down by several percent, and the shorter buildings up by nearly 10%.
This leaves me with a quandry. Should I keep the digital files for ease of replication, and live with the scaling differances, or should I go the route of having physical copies (the copy function on my printer, oddly, did not have this issue when I produced replacements for the parts I was missing) and just copy the copies if I need more?
The good news is that the first roof I built from the dimensions of the original pieces works well for those parts. So direct copies (or spare card parts) I can fabricate roofs for in ~15min/roof.
Spectrar Ghost
Postby slartibartfast » Mon Jan 11, 2010 8:06 am
While the scaling problem may be annoying, a copy of a copy may be worse. Im just glad to have access to the buildings again. I also have the Ork buildings if you want to copy those. I may have some other types of buildings they did if you are interested.
You start out with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before emptying the bag of luck.
Anonymous
In heaven everyone will have a Batmoble. - Kevin Smith
slartibartfast
Postby Spectrar Ghost » Mon Jan 11, 2010 10:38 am
Added measurments for Original and Scanned versions.
@Slarti - I'd be happy to scan your Ork buildings. Are they entirely card? It's difficult to tell from the pictures I can find, but it looks like they are "Tab A into Slot B" construction? Having all these scanned in one place seems like a good idea to me.
One thing about Orkitecture is it is so simple in terms of external detail that I could probably design 3-4 templates myself, and really crank it out. It would be less versitile than Imperial architecture, but probably several times as fast to build. One thought though - how many stories do Ork buildings usually run? I would think 3-4 tops?
Nat
Spectrar Ghost
Postby Matthias » Mon Jan 11, 2010 11:55 am
I literally have like 200 of these buildings - I can bring some up on the 16th if you need them.
Postby Spectrar Ghost » Mon Jan 11, 2010 12:02 pm
Make my life easier... sure.
Spectrar Ghost
Postby Shaggrudd Dethblasta » Mon Jan 11, 2010 6:48 pm
I like the idea for the buildings especially because of the campaign.
"Why can't you dig how beautiful and righteous it is", Oddball
Postby Lordgoober » Mon Jan 11, 2010 7:48 pm
Heck, it would good to have a supply of these buildings available for Adepticon's event.
Postby slartibartfast » Tue Jan 12, 2010 7:27 am
Y es nat they are Slot a into Tab b stuff but they would be more buildings. Plus I have 1 imp building that is all cardboard too. I ll find them and bring them sat.
Anonymous
slartibartfast
Postby Spectrar Ghost » Tue Jan 12, 2010 9:19 pm
Oh, don't mistake me, slot A/ tab B is fine, I was just thinking if they would be significantly harder, on the scanning or making end, to do because of it.
Pointy-ear confucious say: When advancing, seek cover. He who does not seek cover, does not live to. He interestingly shaped smear in grass.
Spectrar Ghost
Return to Epic: Armageddon
