Aegis Lines with Gun Emplacements
Postby Lord Krungharr » Sat Jul 21, 2012 9:41 pm
Can any model (even the opponent to the gun emplacement's owner) in base to base contact with the gun emplacement control it? Or just the owning player?
Also, if a model fires from behind the Defence Line walls, let's say 3" behind, does the unit he's firing at, let's say 15" away from the walls, get a 4+ cover save too since they are behind the walls relative to the shooting unit?
And would it be different if the shooting unit is right up against the walls/slit-openings/crenulations?
Re: Aegis Lines with Gun Emplacements
Postby Cptn_Snuggles » Sun Jul 22, 2012 11:52 pm
Surprisingly it is pretty clear in the Rulebook for a change. Terrain can be used by either player including the gun. One unit within three inches (or two I can't remember) can use it. Same goes for com relays. Either army can use them.
The walls grant cover to those within either two or three inches from the walls (again not sure without my rulebook in front of me). So the unit in your example that is 15 away would not.
